yes, i have a old beo4.
you think i must have the new one with the new navigation button
Not necessary. In the menu of your tv you can disable the navigation button, so you can use it with your remote.
Hi Koning,
I completely agree with you. This mediaplayer is simply the best in term of ability to read any format, display subtitles... It just need to be hidden (it is not very design... ;) and lack from a nice interface.
sergio
I have the smart H1 and it works very well with the puc code in the television Here is a link for making a movie wall for dune mediaplayers
The Samsung pictured looked very nice to me. Thought I would read some about it and came across this Samsung........
The PUC list is pretty big at this point and I don't know if it being published in print anywhere, but your dealer can certainly confirm the support for any device.
The good thing about Blu-Ray players is that they tend to recycle remote codes within brands. So Sony, Panasonic, Pioneer, Samsung etc. are all generic codes that operate any blu-ray player.
Same goes for media servers, and other types of set top boxes.
Rant....
I do find asking a dealer or service for which boxes can be controlled by a STB akin to pulling teeth. Maybe its my approach...
Beoaus.
Rant over.
The new BDD7500 will work perfect en fitt's very nice at the back side of a beovision 10. It's also availeble in black
the new PUC works only with the new beo4!
i bought the new one and voilà it works!!!
The PUC version 2.XX is meant for the new Beo4 1710 with navigation button, which got two sets of left-right/up-down buttons, that send different commands / for channel up/down and next/previous. But should also work with "older" Beo4s. Try Go - UP , GO - DOWN, GO - LEFT....or disable navigation button in BV10s MENU.
Stefan
