BV 10, and blue-ray
Hi guys,
A quick question, I've just learned what DVB box I need to use with the BV10 to get the STB controller to work, but what about Blue-ray? Can the BV10 control Blue-ray players?
Andreas
Yes,
the PUC can be loaded with some blu-ray models.
I personnaly use a panasonic blu-ray and it works like a charm (very fast, no pana logo...).
Thanks,
is the PUC list available somewhere?
Do you know a specific Panasonic blue-ray that works?
The PUC list is pretty big at this point and I don't know if it being published in print anywhere, but your dealer can certainly confirm the support for any device.
The good thing about Blu-Ray players is that they tend to recycle remote codes within brands. So Sony, Panasonic, Pioneer, Samsung etc. are all generic codes that operate any blu-ray player.
Same goes for media servers, and other types of set top boxes.
Thanks Trip,
Could anyone give me a good tip on which Blu-ray player to buy?
Just found a very cool BR player... Wall mountable.
The Samsung BD-C7500, not B&O, but pretty cool.
Will this one work?
There are two very slim Samsung Blu-Ray players that are very well suited to BeoVision 10, and are controllable with Beo4 & 5 via the PUC table. In addition, STBbrackets make mounting solutions to allow the player to be located “out of sight”, on the rear of the BeoVision 10 (and other BeoVision models).
It really is a very smart solution.     Maybe visit http://www.stbbrackets.co.uk/?page=prodlist&catID=37
For those of you who want to have some fun configuring your BluRay player (or any other device) onto your BeoVision, play with this on line configuration tool…………………………. http://www.stbbrackets.co.uk/?page=configurator This is how the dealers select the correct bracket configuration and advise you on what can be added to your TV when you buy.
I have also seen STB’s latest configuration tool which they demonstrated to some acclaim at the dealer conference in Aarhus…..wow that will be something when it is launched in the spring………..I’ll post details later
hi
i have the samsung bd-c7500 connected to my bv10-46 with puc.
the only problem is the up/down and left/button don't works! (the installation have make my dealer).
any ideas for this problem?
tanx
Are you using the "old" Beo4?
Navigation button is probarly "on". Navigation button is used for the new Beo4.
