Buttonless remote
bayerische wrote:
If we want to make our Beogear more user friendly, "thinking out of the box" shouldn't start with the remote.
I'm going to defend Bikkel one more time and then he's on his own!😕
Personally I think that the interface (remote in this case) is exactly where you start. Start being the operative word. The way a person interacts should drive the design and if we can reduce the buttons on the remote where operations are complex and resource intensive (I'm using the term "intensive" relatively!) to the screen where the interface can be laid out more intuitively than that should be the direction. Bayerische is right to cite Apple's approach in making the button essentially an up/down/left/right/go affair and relegating other navigation to the screen where the interface requires fewer compromises.
All that being said, if this was presented at my university where I studied interface design, it would be torn limb from limb in the crit phase, but the approach is admirable and one that is seldom undertaken. To throw away the "legacy" components of a product and build it from scratch as though the idea was just conceived is sometimes a worthwhile undertaking and will always find a niche market of individuals who are open to a truly unique use experience.
Nice job actually, I like it.
I love any new approach to an everyday object to make our lives easy. However, unless I misunderstood the Bikkle, I understand you have to use it on a flat surface. That means that when ever I want to change tracks, adjust volume etc. I have to lean forward to operate it. You are in effect tied to the coffee table or desk.
A remote should be just that - able to change volumes, channels and tracks from the comfort of your armchair and not have to lean forward each time.
Great idea though.
bayerische wrote:
1 reach for the Bikkel
2 swivel it around
3 let go of the Bikkel
That is just about the funniest thing I have read in ...oh... 6 months! Thanks Andreas.
burantek wrote:
2 swivel it around
How did I scroll past that one!?
"Let go of the Bikkel" is going to be my new mantra!😁
TripEnglish wrote:
burantek wrote:
2 swivel it around
Hey guys, if you are happy, I'm happy! 😂
Quit swiveling your Bikkel! ...you'll go blind!
Back to the OP: Is this the first prototype? I look forward to seeing your project progress! 🙂
My avatar is the concept buttonless remote
bayerische wrote:
TripEnglish wrote:
burantek wrote:
2 swivel it around
😂😂😂 Very funny, indeed! About the first thing I read this morning, and Andreas, you already made my day! @ Trip, your signature is also very cool!
If you look at the first part of the clip (with display), you will see that you can operate it without table (in hand as well).
