If you look at the details it is definitely not a altered computer mouse. I thought out of the box. I am in search for the ultimate in simplicity.
Let's compare:
When you change the volume or change channels, (this is were the average user uses his remote for). Let analyze:
1) You have to pick up the remote.
2) You have to direct it the the equipment you want to control (in case of infrared).
3) Now you have to look and find the right button to press.
4) Press the right button.
5) Put the remote back at its place. (I guess you don't sit with the remote in your hand all night).
Now lets count. You just performed 5 actions.
With this
new concept you can do all that with one action.
Most people grew up with a 2 button radio. And are familiar with the old
fashioned analog dial to control the volume.
See it from this way. There was nothing wrong with the old fashioned
dial button. At the time the remote was invented the concept i suppose
was simply not possible.
To compare it with a mouse is wrong for the following reason:
A mouse is a pointing device and has a direction.
This Bikkel concept has no direction. You might think, what's the point.
If you sit on the other site of the table and you turn the Bikkel, the
result is exactly the same as someone on the other site. This again
adds to simplicity. So as long as i can find this Bikkel in the dark, i
know how it will react when i rotate or circle it.
