Hi:
Please feel free to move this post if it is in the wrong place. I know it is off topic but I guess someone on here might be able to shed some light on the issues I am experiencing:
I
assembled a PC so that there is the mainboard, graphics card and RAM
all in the case. Heat sink, cradle etc are all in and the power supply
is connected. The board is fixed to the case with plastic mounts so as
to avoid the risk of any shorts.
The problem is that when I fire the machine up, it all turns on for
either a brief period of a couple of mins (or less), or for as long as
it is left. There is no picture to the graphics card. There is a floppy
drive attached and when I first turned the machine on (without monitor
attached) the drive made the normal grinding noise expected on boot up.
Since then however, it hasn't done this. The CD ROM attached does have
power to it and the tray opens and closes.
In conclusion there is an issue with the display. I am pretty
certain that I haven't damaged the processor, when the machine is on I
have checked the heat sync and it is barely warm. I haven't over
clocked it or anything like that. Is there anything that springs to
mind? My friend has suggested that as there is no HD attached that it
might be switching itself off as there is nothing for the machine to
read/do. However this explanation does not seem to make any sense to me
because surely for the PC to know there is an HD there, I would need to
instruct it to look through the BIOS? Of course to do that, I would
need to access it with a working display.
I have tried two AGP grahics card but still to no avail.
Interestingly the graphics card supplied has an onboard fan which does not rotate.
Could this be a power supply issue (I recycled it from an old machine - it is connected properly - small connector near processor and large rectangular connector also)?
I hope I haven't cooked the processor but if I had surely the machine wouldn't switch on at all - no circuit?
Any help you can provide would be greatly appreciated.
Graham
