BS9000 power on volume settings?
Hi
My BS9000 Start up every time at Volume 34 (its quite high with my speakers) is there anyway i can adjust the power up volume setting ? So i dont need to turn volume down everytime i start the BS9000?
Thanks Alot Dave :)
From the Beo4, set the volume you want, press List until you get A. Setup. Press the OK button in the center of the arrows, then press List until you get S. Store on the Beo4 display. Press OK and it should remember the settings. You can also preset whether you want any bass or treble adjustments or even loudness preset when you turn it on using this approach.
