BS9000 not switching on speakers ????
I have just purchased a BS9000 Limited edition, its approx 8 weeks old, they are connected up to a pair of Lab 8000, i went to turn the system on tonight and the speakers would not switch on, the red stand by light is staying on.
Being a sparky, i have tried various things: 1) Turn the mains power off to the speakers, wait and then turn back on
        2) Turn the power off to the BS9000, then back on
        3) I have noticed that the operation of the BS9000 still works, you can turn between radio / cd
But the speakers are not switching on, has any one come across this problem, can any body help me with this one please.
Put it in option 1.
Standby + list
press list several times until option? appears,
Go
Aopt
1
Go
red dot blinks to confirm
Has anyone changed the switch setting on the speakers?
Hi, i have just tried that, and the speakers are still not turning on ??
the unit is in option 1 mode
Thanks for the help, could it be the switching side of the 9000, not sending a signal to the speakers, or a possible loose wire when they joined the two speaker cables togeather( Solder ) @ the 9000
Many thanks any way for the advice
Hi peter, how do you change the switch settings on the speaker ??? As i have not touched the speakers since the unit was installed
Cheers Martin
ah... just how/why were these modded? have they been tested/have they worked before??? sounds a bit odd to me?
when they originally installed the speaker cabling, a cable was routed to each speaker, and at the 9000, they soldered the 2 x cables  togeather, and used only 1 output on the unit, this has been like this for 6 years, when they installed my previous BS3000, should this be o.k ??? Would there be any sound difference if i split the speaker cables @ the 9000, into 2 x outputs
Why solder 2 cables into 1 anyway - B&O have a splitter for that!
My guess is one of the soldered cables has split at the switching pin.  Try one fresh cable to one speaker first to test the BS9000...
Lee
Good call Lee,
There are so many cable options available for Powerlink that it should rarely be necessary to join cables together on site.  I would suggest completely disconnecting the existing cabling (from both BS9000 and the speakers) and then trying one speaker at a time with a new, good quality cable.
I will be surprised if this doesn't solve the problem 😕
By the way, if you do still want to have both speakers run into one Powerlink socket via a "Splitter" cable, let me know and I can sort out a more robust solution for you.
Best regards,
Steve.
Did you get anywhere with this? 🙂
Lee
