Bs7000-bv8-40 problem
Hey all :-)
i have my Bs7000 connectet to my bv8-40 with helt from the 1611 converter.
The problem os that when i press CD one the beo4 my bv turns one and only my bv and not the bs7000
then the speakers turns one but only a "mmmmmmm" sound is coming of you know what i mea :-/
Hi situation,
First try to disconnect all from the mains - then reconnect the BV and the BS....
...and finally the converter!
Do you have a ML-splitterbox in your setup?
Greetings Millemissen
What u mean with ML-splitterbox? :D
but is there some thing that i need to do like option 0-1-2-3 or what ever with the Beo4?
He means one of these:
Ohh okey :-) But no i dont.
i use a Datalink kabel from beomaster 7000 and up to the 1611 converter.
and then Masterlink kabel from 1611 to the bv8-40 masterlink in
Well, I actually meant a 'Junction Box', which is the correct name for the little box you use to split one ML cable into 2 or more. Quite often reasons can be found in a faulty connection there.
Anyway, assuming you have no no speakers on the BS7000 in that room, the options are:
Video - opt2
Audio - opt0
Please reed the userguide of the BV8-40 for details - page 36.
If you still have problems try changing the ML cable and/or the AUX cable.
Just to be sure...
it is the Tv/AUX i need to use ind the bm7000 right?
Yes!
Well is there eny thing that i have to do ind the menu one the bv8?
or eny thing? Im going to try to re-connect all the kabel soon
No - just setup with the Beo4 as descibed in the userguide.
