BS3200 not turning on with remote
I have a BV9 linked to BS3200 - we had recently been away for a week and I disconnected power from both the BV9 and BS3200 .
I now find that when I try to turn on BS3200 with remote Beo4 or Beo5 it will not turn on, however it will turn on if I use the units own buttons, but I do not get any sound.
I have unplugged power and master link connections but still BS3200 will not work.
The BV9 is working without a problem, anyone any thoughts.
First Make sure that both units are not awaiting pin codes.
Secondly make sure bs3200 has been optioned corretly, if you only have the bv9 and bs3200 in the same room put the 3200 into aopt 0.
on beo 4 press and hold standby and list together until "add" is display in beo4's display then keep pressing list untill "option" is displayed then press go, then press "list" until "Aopt" is displayed, point beo4 at bs3200 and press "0", standby light should blink once.
If your using the bs3200 standalone and not connected via ml then press 2 instead of 0.
Hi Gary
Thanks for reply,
I have done as you said but still not working.
I also Vopt. the BV9 to Video Option 2 - the strange thing is that this has only happened since I returned from holidays, durning which time I had disconnected power from the BV9 and the BS3200.
If PIN-code and A.Opt / V.Opt setting has already been checked
try the following procedure - sometimes it resolves the problem:
- disconnect (unplug !) power of your TV & BSd 3200
- disconnect ML cable(s) and reconnect them again - check for tight fit
- wait 2 min, then restore power
- wait 1 min before switching on
Thanks Vienna
Tried as you said but still no joy, anything else I could try  or is call dealer job.
