onnnnn wrote:
Graham
Hi again,
I am just a wee bit confused so I need some clarification please.
You suggested I order 2 cables which I already did.
One set will plug into my B@2300 AUX with the RCA plugs going to the pre amp I just purchased as well. So where does the second cable go as the Beogram has a set DIN plug?
Regards,
Jonathan
Your pre amp does not have a DIN socket to accept the cable from the beogram so............
You need one DIN female to RCA male for the input connection from the beogram and you need one DIN male to RCA male for the output conection to the 2300.
This is why I suggested that you talk to steve@soundsheavenly first, before you make a *** up!!
Steve can supply exactly what you need by simply emailing him.
