Carolpa wrote:
BL4000 connected to Core
BLC setup as ASlave
BS9000 no speakers connected (= option 0)
BS9000 ML connected to BLC
BG connected to BLC line in
I have successfully tried that setup. However, I understand from
setting BS9000 in A.Option 0, this also disables the IR transceiver.
The
issue is that controlling the BS9000 from the B&O App provides only
a very few features (for me I can only switch on/off the BS9000, select
source and play/pause/skip track of a CD. I cannot even change CD). I
would prefer to use the Beo4 rather than the local buttons on the
BS9000.
I have then tried to set it in A.Option 1, and by doing
so I can now use my Beo4, even if there are no speakers connected to the
BS9000.
Is this an incorrect approach? I am familiar with the
DIN speaker sense plugs from SoundsHeavenly, which I might buy one of
eventually.
Additionally, I attached my BG to the line-in of the BLC. I struggled from the app to select line-in source of the BLC (I could only see the sources from the BS9000). My first attempt was to set-up line-in sense, which basically solved it.
Next, from the App Settings menu of the BLC, I changed "Products controlled by apps" to BLC with speakers (even though there are no speakers connected). Bo doing so I can now select line-in from the BCL (and sources available on the BS Core - but if I pick from a source from the Core, I can obviously not link the Core and BLC in order to play the music on the Core).
