Hello,
is it possible, to connect a Bluetooth headphone to BS Core? How does it work?
Digi
Hello,
Digi
Hello Digi,
Beosound Core doesn't have a bluetooth audio output if I recall correctly, but there is nothing to stop you adding an external bluetooth transmitter (ideally please choose one with a "press to pair" button that supports ad-hoc pairing) to give you a wireless connection to your headphones.
Please feel free to get in touch via my sponsor link below if you would like any help in finding a suitable bluetooth transmitter or the cable to link this to the Core.
Kind regards, Steve.
Hi DigiWhy would you want to connect from a BS Core when all of the sources are available as Apps on a mobile device which does support BT connection to headphones? You would also be restricted to about an 8m listening position instead of being portable with your phone or tablet. If you want better quality sound then you’ll need a wired headphone DAC like the Chord Mojo.Hello, is it possible, to connect a Bluetooth headphone to BS Core? How does it work? Digi BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8+H3
