BS Century
Hi , just bough a really poor cosmetic/mechanical condition bs century , even tough is 75% working ( cd is completely dead , not spining ) but i love . Its a little bit tatty , will need to change fabric on speakers covers, there is also missing front glass panel, and thats the question, does anyone know where can i get it from ? can be used ( cheaper = better ) Erm..
Regards
Mike
finding a used door will be rather impossible. why not order a new one? they are still available and not that expensive, they will ask you for the serial number of your century as there were two different versions of the glass door assembly.
and regarding the speaker covers: these can be reclothed in any color, just unscrew them a the back and take them off, they can be completely disassembled in four pieces. you just need a very thin fabric, similar to the fabric of the other beolabs.
Try Leslie on this forum, he will be able to help you with the door and brackets for same
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thanks for reply ,  Just finished reclothing speaker covers , using greay women leggings burned into frames with soldering iron  lol overall cost = 2 pounds 50 pens and few mills of lighter fuel  πŸ˜
Regarding the buy of new doors , I bet they will be more likely +-80 pounds , that makes them expensive to me, as spending half of my weekly wage does not makes me to smile :P. So i rather keep looking for 3rd party replacement or used one of ebay
Just to mention that this BS Century cost me 25 pounds :) i think, that's a good deal even tough cd is not working
Regards
Pictures please, maybe I can have a laugh to? 😁
If you still have the metal bracket it might be a cheap option to by a glass teinted door  with same size chamfered edges (approx. 15E).
Have fun! πŸ˜‚
link
link
link
anyway no the previous owner bin whole broken glass unit with bracket :( . however that sliding part is still there and it moves!
Great job well done fella!!!!
Jonnie
Thanks!
Can any owner of bs century measure for me, exact the doors high and length and  also how deep they are. Please
This not funny, this is good!πŸ€’
Size glass panel 330x175x4mm
Two type of brackets used for the CenturyπŸ˜‰
Thanks Leslie!
Do you think clear cast perspex acrylic cut to the size you provide will do ? or it have to be glass ?
