Bs 9000
Hi guys Happy New Year,
I'm new  on beoworld forum,
I have a problem with  beosound 9000 mk1 cd start spin( to my opinion slower than a regular) and after 5 Seconds stpo an go in reverse spin very fast after that Stop and on display  write pause. That's happened on all CD slots.
I Download service manual and do testing,test 27 show me CD error 3 that's mean tadial error, second error is a APS error 15.
I'm familiar with electronics and I go through service manual and I open,clean everything and nothing change. I have functional MK2 CD player and these two CD players have  same CD mechanisms but different connection, and I cannot use CDM from MK2 to MK1, but I test CD plate(display) and he's fine.
Anyone has experience with these errors.
Thank you in advance
Dragan.
99% laser pick up is faulty.
If you heve BS 9000 MK1   /  2521....2526 typ  /  and CDM 12.6 typ of laser  /  then you have 20% chance of repair in chep way.
If you have CDM 12.4 than you can repair it cheap way with 15usd laser from Ebay.
This is my experience .
If anyone has a better opinion of repair version MK1 with Laser CDM 12.6 please to share the experience of successful repair.
Hi, thanks for quick response,
My beosound is MK1 type 2523,laser is vam 1205, which flat connector for laser motor
I have MK2 with the same laser head, I can try replaced and see what happens😕
My laser is same like this one
http://m.ebay.com/itm/Philips-optical-pickup-assembly-CDM12-4-Pro-players-Rowe-Rockola-jukeboxes-/112203280055?nav=SEARCH
Go for it :)..it should be ok !
I have had exactly the same problem with my 9000, but it started when I started using "home burnt" CDs.
I have stopped doing that and I now only play my original bought CDs. However, I had to (VERY carefully) clean the laser head (the little glass bubble in the moving part with a small swab that was wet with ethanol/methylated spirit. But again, be very careful.
Now it has worked for years, but I have to play a CD weekly to keep it in good shape
II will try that tomorrow now it's too late 2:30 😁.
Anyway thank you so much guys have a good night
