I have 2 pairs of MS150s and I'm considering wiring them in Parallel. Does anyone have experience good or bad with this setup?
https://beocentral.com/beomaster8000
"The colossal Beovox MS 150 was the usual choice, and although it was well matched in most respects, due to its 8 ohm impedance it could not make use of the full output of the amplifier. The Beomaster 8000 was rated at 150W only into 4 ohms, the figure fell to 100W if 8 ohm loudspeakers were used."
thanks
