Hello!
I just got my first piece of bang olufsen!
The bad news is that there is no sound. The guy selling it just took it down and says it was working fine.
The display on the Beolab shows source but doesnt show volume (see image).
There was no powerlink cable so I bought one from the local store, 5mm thick ( see image). I have been calling 3 bang olufsen stores, 2 of them says its the wrong cable and the right cable is 3mm thick. the other says 5mm is the right cable and instead there is something wrong with the speakers.
EDIT:
I get sound if I:
1. Connect the BL 3000 to BM 4500 via power link.
2. set BL in audio mode
3. power on the BM wich activates the display on the BL, but there is no sound and display on BL shows source and volume as MUTE symbol "_ _"
4. Disconnect the speakers main power from the wall socket and plug it in again.
5. No display at all but there is sound from the BM.
6. I can change volume, change radion channel but if I change source or something else the display om the BL wakes up and there is no sound again.
