Bluetooth transmitter
I am the otherwise happy owner of am Eclipse and a pair of H9i headphones.
But since B&O chose to not add bluetooth connection in the Eclipse, my dealer sent me a bluetooth transmitter. (Marmitek boomboom)
It fits perfectly inside the Eclipse, so it’s not that big of a problem that it’s an external transmitter.
My problem is that it’s simply not good enough, when it’s quiet on screen, a how a low hissing noise in the headphones, and that i can not live with, it’s freakin annoying.
So my question is to you guys, does anyone know of a bluetooth transmitter that is actually of a quality worth buying?
Thanks in advance.
This one I can recommend:
Thank you very much.
Have you got one yourself?
I’m located in Denmark, I’m gonna try to find a dealer with a return policy, so that i can try one out.
The missing Aptx on the H9i’s is a mystery, but even tho’ the transmitter i have is not very good soundwise, there is no delay, so I’ll give this one a try.
As to your advice on the “optical out” solution, I’ll try it out, but do you really believe the DAC in a 60$ BT transmitter is better than the one in my Eclipse?
Again, thank you very much for your answer, i appreciate it very much 🤒
Fidse,
yes I have one and for me it works fine. But my first try was a failure like yours - sound wasn't bad but pairing and stability a constant disaster. So I returned it. This one I can recommend and I hope your experience will be positive like mine.
The missing aptX is not a mystery, because there are additional licensing fees involved, but a cost saving measure of the company.
According to cables and connections - I'm no expert on this but isn't this device just a transmitter not including a dac? Digital to analogue conversion will be done by the built in dac of your headphones. As far as I know.
Optical cables, not susceptible to electrical problems such as ground  loops and RF interference, are an advantage.
Since you will get all types of cables delivered with the transmitter, I suggest to try it out what sounds best.
Regards,
Ulrike
 Can you please explain which cables are used, connected to which output of eclipse? And how the settings are; I would like to install a transmitter myself...
