Okay, now I can see the picture from my new LG Blueray player and I have an IR cable in IR2, how do I configure the BEO4 to control the Blureray Player?
Regards
Rob Cooper
Regards
Rob Cooper
Sorry Rob,
I can't remember which BV you have 😁
You must assign the BRP to one of the ports (you probably already have).
In the same menu you must chooce the 'ir socket'.
If you have one of the 'new engine' BV's, you then can download the apropriate PUC.
Update: it was an older BV7, right?
If an older tv - either it is in the list you see, or you must have to have the BV updated/flashed from a B&O technician.
Without the PUC software, no controlling via Beo4.
The Beo4 must not be configured - it just works, when you push the button/list entry for the port assigned to the BRP.
Greetings Millemissen
I have a BeoVision7 MK1
BRP?
BRP = Blu Ray Player 🙂
