Anybody knows if B&O will release a Blu-Ray player soon?
Thanks.
S. Fray
Thanks.
S. Fray
Dont think they ever will release a Blueray player.
I can recommend Sony BDPS300/350 which you can easily control with a bang & olufsen remote either via:
Hi!
I would much prefer the panasonic DMP-BD50 rather than the BD 30. The BD-50 has internal decoding of bouth Dolby True HD and DTS Master Audio and the BD-30 does not. BS3 cant decode the new sund formats so you will have to let the blu-ray player do it and then send it to the BS3.
Ahmet!
i'm looking forward to a bv7/40 with bluray
now THAT will be interesting !!!
I agree too, as having the Blu-Ray inside the BV7 40' allows us to keep the B&O integration.
Guy
Blue-ray isn't going to take off. It's a treat, yes, but it's just not going to catch on anything like DVD did and B&o is right not to have a Blue-ray, i see us moving right away from physical media.
You watch...
good call
