Blu-Ray from B&O
Anybody knows if B&O will release a Blu-Ray player soon?
Thanks.
S. Fray
Sorry for my english. Bang & Olufsen just launched a blu-ray built in for BeoVision 7 - 40 MKIII in early 2009. There will be no solution outside.
Bye
Dont think they ever will release a Blueray player.
I can recommend Sony BDPS300/350 which you can easily control with a bang & olufsen remote either via:
I recommend you a compatible external player like the Panasonic DMP-BD30.
Needs only to update the list of the STB-Control for use this player with the BEO4 or BEO5
Hi!
I would much prefer the panasonic DMP-BD50 rather than the BD 30. The BD-50 has internal decoding of bouth Dolby True HD and DTS Master Audio and the BD-30 does not. BS3 cant decode the new sund formats so you will have to let the blu-ray player do it and then send it to the BS3.
Ahmet!
i believe the samsung BD-P1500 and BD-P1400 will also work
i'm looking forward to a bv7/40 with bluray
now THAT will be interesting !!!
I agree too, as having the Blu-Ray inside the BV7 40' allows us to keep the B&O integration.
Guy
Blue-ray isn't going to take off. It's a treat, yes, but it's just not going to catch on anything like DVD did and B&o is right not to have a Blue-ray, i see us moving right away from physical media.
You watch...
good call
