Back again,
got the newer version of bl3500 and it was sw 3.3 🙂 so I'm now in phase with the blgw compability, did not make any difference in the
wireless 1 connectivity with bm5 though. Let's forget about the possibility to use them (wireless 1) in a blgw/masterlink setup and move on.
Which I have🙂 and bought a blc nl/ml, a core and ordered a couple of beolab 18.
Maybe I should start a new thread but I'll try here first; my objective is to replace the bm5 with the core as audiomaster but still
have access to the bm5 and it's N.MUSIC, is that possible?
My system is mainly audio, looking at the blc menu it looks like You have to choose audio either visible on the ml or nl not both?
The closest You get, as far as I understand , is Source Center but then N.MUSIC ends up visible on the ML side and not
on the NL side.
Any advise much appreciated
Baaz
