BLGW
Hello All,
        I recently purchased and installed a BLGW on my network.  I have also installed the BLGW App on my iPad.  The App does find the gateway on my network but is asking for a “User Name & Password.”  I assume the App is referring to the User Name and Password from the previous user which is unknown to me?  Do I need to reset the User Name & Password?  If so, How do I reset it?  Does anyone know?
Thanks!
Ed
Did you try:
Admin — Admin
Or do a factory reset
Tried useing Admin—Admin but doesn’t work.  Where do I get instructions on how to do a factory reset?
no caps: admin/admin
FYI, the BLGW and NL/ML Converter are the same hardware. Sometimes they have been loaded with software to be converted to the other.
You might check to make sure this isn't actually an NL/ML Converter by enter in your web browser the address: blc-********.local
Entering the serial number instead of ********
see the picture
There is a button in the hole next to the light.
Take a paper clip, bent it and press the button as explained in the picture.
Hi Beojeff,
        admin—admin (in all lower case letters) does work!  Looks like the gateway is really a complicated device to program.  I have downloaded the BLGW installation guide and looks like successfully downloaded the update.  I am willing to tackle the task of programming and looking forward to what looks like a definite CHALLENGE!  I consider this as having enrolled in “BLGW class” for the fall semester.  Hopefully will have it up and running by semesters end in December 2021 and get an “A+” out of the class.  Do you have any hands on experience?  Any “pearls of wisdom?”  Thanks again for all of your help!!
Ed
Sjock601 wrote:
Hi Beojeff,
Ed
That's great news. You'll find the learning curve of the BLGW is really short. Also, you'll find building the macros to be really FUN. Once you make a simple macro and see that it works, you'll get instant satisfaction and confidence. The Philips Hue lighting system is a great system to add to the BLGW.
