BL6000 + BL11 or..
Yes I've heard about it, but why can't we just buy the Beolab 14 sub?
The Beovision 11 and Beolab 2 combo was not an impressive one, although to be fair it might have been my installation. The TV gave it everything, seemed to give up momentarily whilst the Beolab 2 burst into life and took over the bass, and before you knew it the Beovision 11 was at it all again.
Very agricultural in its distribution of bass, and not a patch on the Beovision 7/Beolab 2 combo I had! Makes me wander how adept it will be at integrating older speakers.
Actually, that was on the list for me to ask my dealer yesterday, but forgot to pose the question! I also wondered if it was possible to use the Beolab 14 sub. You wouldn't see it in my room as the BL11 is hidden behind the BV11.
Sadly by the time I'd told the dealer about my Playmaker issues, BV11/Apple TV issues (HDCP keeps blanking the screen) and so on, I forgot to ask about the BL14 sub. I did find out that the BL12s are coming out in that topaz grey colour.
And, yes, I've never tested a BL2 with the BV11. I only ever had it connected to the BV7 (in the early days, I had a 7.2+BL2, which I switched to 7.4+BL9s, which was a superb combination).
I made my choice, tonight i have bought an nice white demo BL11 and a set of wallbrackets for the 6000's and have collected them from the seller.
Tomorrow i will hook everthing up for testing. I hope the sound is what i want it to be.
One thing is for sure, the BL11 and the wall brackets look beautful..
