Hello,
While i'm redoing my living room its also time to change the audio setup a bit.
Currently i have a set of lab 6000 playing in my 40 M2 living room.
I do like the sound of the 6000 but i do like a little bit more bass and dynamics.
Now i think i have two options: keep the 6000's (which will be placed on wall brackets) and ad a BL11.
Or change the lab's to a set of Beolab 1's. Both options would cost me about the same (second hand).
What combination do you think sound's (and looks) nicer? I listen to everything from trance to classical at mostly medium levels.
This how the setup looks now..
BL6000 + BL11 or..
Purely on looks given how great your current set up looks I would vote for the BL11.
wrong message sorry
I sold my 11 and barely noticed it was gone.
Chris, you were only telling us about the poor bass from your BV11 when pushed hard? Surely the two are related :)
I still have my BL11 and I would definitely say it improves the bass on the BV11. Was watching Oblivion the other night and was impressed with the bass from the TV. Same with Django Unchained last night - I ended up having to turn the volume down on a couple of occasions, particularly when there were explosions.
The BL11 isn't anywhere near the level of a BL2, but it's definitely better than just having 6000s or a centre channel on a BV11.
I only ever used the Beolab 11 with my old Beovision 10, so that was my only comparison.
With regards the Beovision 11 and its bass, as you personally know it is a much more capable TV than the 10. But there are times when it as a flat screen can only do so much, my little boys Beovision 3 is somewhat better.
Can anyone tell me what and how big the difference in sound between the 2 options is?
How is the low-end when you compare the LAB1 to The BL11 and 6000?
From what i read the lab1 may be to bright, especially in smaller-medium rooms with lots of hard surfaces like i have. The problem is because i think i probably will be buying the speakers second hand its difficult to compare the sound..
Purely based on looks i think the BL6000/BL11 combination is a slightly better option, my wife on the other hand likes the BL1 more.
Hi, your current set up looks good and putting the 6000s on the wall is nice touch.
I tried a bl11 with 8000's and it was a non event.
I have lab1s in a hard surfaced room (with a bl2) and really like them. The detail you can hear compared to my 8000s is amazing.
If you were to put lab1s into the existing set up, is there enough room both sides of your unit to avoid them looking wedged into the corners ?
Have you considered the base enhanced 8000s wall mounted ?
Lets know how it works out for you.
If you listen only to music the beolab 6000 is really bad.
You get tired.
The beolab 1 is a nice speaker but the tweeter sound very hard,so in a hard surfaced room i think that's not a good idea.
Definitely, I agree. However, the BL11 does add a bit of oomph, mostly where there are explosions in a film - I got caught out watching Django Unchained on Friday, a couple of times, where the sound was high, windows open They heard the explosions in the neighbouring garden :)
Hopefully this new subwoofer is even better. It's supposed to be a replacement for the BL2. Was always impressed with the BL2 when connected to a TV.
