Bl5... FireWire and Mac
For whatever reason I can't find archives on this subject, even thou I remember reading...
What is the best way to connect the beolab 5 to an iMac using FireWire connection, or else? Soundproof talked about a particular soundcard but I have no knowledge about those devices.
Thank you
Hi
I'm using the cambridge DAC Magic Plus
carlito wrote:
Hi
I'm using the cambridge DAC Magic Plus http://www.cambridgeaudio.com/summary.php?PID=872
USB out from the Mac - DAC Magic Plus and Beolab 5 connected with SPDIF cables.
Pro: With the DAC Magic you can use several digital inputs and the SPDIF output to the Beolab 5
Cheers
Carlo
Even thou, it's called DAC, i hope it will not convert to analog before reaching the bl5... I'll look to it.
Thank you for the input!
carlito wrote:
Hi
Cheers
Carlo
Well, it looks like its the perfect device, actually. Thanks again.
No, digital to the Beolab 5!
I'm using the analog out for the Beoport which is feeding my Masterlink Network. If you are using only an iMac and a pair of Beolab 5, you can also buy a cheaper Toslink to SPDIF converter.
The DACMagic is a great digital Hub - also Headphone output is pleasure with my AKG 701
Im only worried the Dacmagic will mess with the signal since it always upsamples?
Rgds Tom
That's the reason why I did not buy the dac magic.
Instead I got a TCImpact Twin. But I have yet to finalize the installation thou.
The archived link is here:
/forum/general-discussion-and-questions/bampo-ir-and-raspberry-pi#post-2138770
Regards,
JR
Thanks for the link.
Actually, those posts are the reason why I bought a TC impact. But I'm still struggling to understand how to properly setup the device... Too many options that I do not know much about...
Edit: by the way, bayerische is very kind and he is helping me by providing with information.
