I have had a pair of BL3 with BS2300 in my bedroom and BL9 with BS9000 in the living room for quite a while now.
After buying a BS3000 with a pair of BL6000 as rear speakers (simply adding a 2nd Stereo system to the living room and feeding it with the rear channels of the sound) I´ve been fiddling around with different options on how to set the speakers up.
When i had a BL3 as center speaker i noticed that it was much quieter than the BL9, even when "giving it the same sound" as one of the BL9.
So i put the BL3 and BL9 as a kind of "couple" stereo system with 2 of each kind for each side and hooked the 3s through the 9s to the BS9000 and turning them on/off in all possible ways to listen to the same musical pieces.
The difference is enourmous. It almost appeared the tweeters on the BL3 were off. I checked by squatting in front of them and covering the mids - they aren´t. I use fully wired PL cables everywhere - the service manual for the BL3 says to use MK3 semi balanced cables; could this be a problem ?
tl;dr: How can i check wether the tweeters are working correctly ?
BL3 Type 6892 Serial: 17xxx14
BL Type 6217 Serial: 22xxx05
