BL18 connected to multiple devices?
Hi B&O fans:)
My BL18's are connected to my BV14(wireless) - but I wonder if it is possible also to connect them to another device like a sonos unit? The reason is that I would like to stream music to the BL18 without have to power on the tv.
/Kim
I don't have BL18s I have 20s. My BLs have a switch that toggles between L - R - WIRELESS
I have them operating with two "wired" inputs: powerlink and optical so the L or R settings work.
I don't se how you could have two alternative wireless (wise) inputs for my 20s.
Nor one wireless and one wired.
andersenpost wrote:
Hi B&O fans:)
/Kim
No
I asked once if I can use them with a playmaker.
The answer was no.
You could attach something and change the switch each time between wireless etc but it's a pain in the A.
I have sent music via NL to my speakers before (18s). The TV switches on but mutes the pic.
No, it doesn't work. I asked B&O because I have the same problem.
I have a BV Avant and a BS Moment in the same room. First I have connected the Beolab 18 to the the Avant But everytime when I want to listen music with my BS Moment, the Avant turn ON.
Now I have connected the Beolab 18 directly to the BS Moment. The problem is, that I have no Dolby 5.1 now.
Personally I would not sacrifice a 5.1 setup because of the 'issue' of the Avant turning on!
Besides - you have a lot more options to control the sound (and make Speaker Groups), when you use the audio engine of the Avant as the hub.
Is the moment not WISA?
I thought you would just make speaker groups on either.
You can connect multiple speakers to the BS Moment (configuring these on the speaker as L/R).
But they will all play - no grouping there.
Speaker Groups is a feature of the audio engine in the BV's.
So, you cannot have a set of WISA speakers that can intelligently share themselves between two WISA sources - like a Moment and a BV11?
I'm actually asking because i'm interested in sharing a Beolab 19 Sub between these two sources. My room forces me to have a TV area, and an audio area, but both could do with a little oomph from a  sub.
Ideally I could share, as i'll never have both on simultaneously.
Supposing that you have a BV11/Avant/V1 or newer tv!
Why not configure a group of speakers (connected via WPL to the tv) for audio only.
This can include the sub as well.
Place the R/L speakers, where you need them - and configure all audio sources on the tv to use this group as the default group.
3 ways to accomplish what you want. 2 require you to wait for the multi-room SW release in Spring.
#1- the easiest would be to run a RCA to Headphone patch cable to the BV14 from the Sonos box. Then hit the Show Picture button and select No Picture.
#2 - Buy an Essence and integrate the two in a one room setup. Then run the Sonos to the Essence line input and tell the TV to turn off after XX time or use the manual show picture button again.
#3 - Buy a NL/ML converter and repeat the steps in #2 with out using it as an integrated one room setup.
All 3 setups will allow you to choose the speaker configuration of used during the applicable setup.
