BL 8000's vs BL 5's
Hi everyone
Just wondering if someone can help me. I currently have a pair of BL 8000's as mains hooked up to a BV7-40 with a BL2 attached. I'm looking to possibly upgrade to a pair of BL5's. The existing system sounds beautiful & i was wondering if there would be a significant difference in sound with the BL5's. I have a pair of BL 4000's as rear's.
Also could anyone see a problem in buying a pair of BL5's from 07 (ex demo from a dealer) as opposed to a new pair. Any software changes etc.....Quite a significant saving on the ex demo pair.
Mark
To your fisth question:
Try comparing this to:
http://3.bp.blogspot.com/_SmQk2jClOU4/TAbiIGQqkPI/AAAAAAAABgM/JdDKg-qUsdU/s1600/lada.jpg
http://static.cargurus.com/images/site/2008/06/05/07/50/2008_bentley_continental_gt-pic-41173.jpeg
And no, they are probably as good as new,  buy demo, might be better sound then a pair of new ones!
The answer you are looking for is "night & day"!
There is no comparison between the two. The BL5 is superior in every aspect apart from not coming as a shiny aluminium object.
10
Well, there are more things they have in common. They are both active speakers and they are both made by Bang & Olufsen. You should just compare them at home in your own livingroom with your own music, and it will all be clear!
As 10 percent said, absolutely night and day, to Beolab 5's advantage.
Except the BL 8000s are much better looking.  Of course that's an opinion...but BL5s belong on the set of Star Trek!  😁
Seriously, both are pretty. Okay, granted, the BL5s looks more like "the bizz", but they look an awful lot better than "real" far-field studio monitors.
The 8000s and the 5's aren't really the same when it comes to the tech. The obvious one is the ALT lens, but it goes deeper than that. The 8000 is  a"hybrid" design. It's not a true active. If you want deep bass and connect a subwoofer to it, the sub will be making use of a passive crossover, whereas the rest of the speaker units employ active crossovers.
I  just did some reading up on the BL8000s, and it seems they "actively" bodged some things in it to make it function. Not to make it sound better and more accurate but band-aided it to a) give it more bottom at the cost of precision and in effect making it into a two-way speaker, and b) put some electronic circuit into it so it would last a bit longer.
So, although I really don't like "night-and-day" comments because they remind me audiophilics, the BL5s are in a completely different league in every aspect.  There is not a single point where the BL8000 is comparable technically or audio wise.  It is almost as clear cut as comparing a passive with an active design, a turntable with a cd, or a reel-to-reel to an uncompressed digital file.
Thanks for everyone's comments. I've made up my mind that i will be purchasing them and can't wait. I was probably more concerned with the second part of my post in regards to ex demo's. Cheers again
I will keep you updated on the difference. :)
No problem. I wouldn't worry about them being ex-demos at all. Money saved, and you know you won't receive a lemon.
Will you attach the BL 5 with the BL 2. My dealer said the bass of the BL 5 is so powerful that there is no need to use a BL 2.
