mr_anders_son wrote:
I have BV9 with BL 8000 as front and BL3 as rear. Before I try I ask if someone has any good points to this
I thinking of to set my BL3 as front and buy BL 4000 or BL4 as rear and maybe sell BL 8000.
I thing it´s overkill to have BL3 as rear or?
thanks in advice
I would sell the BL8000's and use the BL3 as fronts.
Consider buying another couble of BL3's for rears. I would'n say that BL4's is really a choice, taking that you have a BV9.
You could also just go for a couble of BL9's for the front, use the BL3 as rears. But ofcourse it depends on your needs.
I'm sure, that you can get a dealer to show you the different configurations, so you can listen your self.
I have a BV8-40", just bought a couple of BL3's; which Im using as front speakers at the moment, while saving money for some BL9's. They really sound amazing. Even at the price tag.
