To B&Os credit I think the issues are finally solved. My BeoSound 1 & 2 are working great.
Beware of firmware version 1.15.16926
Not saying, that this could cause trouble in a NL environment...Well, I think you might be right. Too bad I can't turn disable Google Cast to test it (there is no "Turn Google Cast off" controls within B&O app or I might be overlooking it).
Today's log btw says: "Google cast doesn't start after update, disable google cast". Well, I did not update the A9 recently but still I'm suspicious it might indicate something linked to Cast issues as you said... Let's see.
It seems that Google has admitted that they have to work on the Chromecast devices to eliminate these troubles.
Quick update from Struer (Jan 12 2018):
They are confident all remaining issues will be solved by the next sw update - expected released within 2 weeks.
Any news on the A6 update?
Actually you can do a factory reset. Then during reinstalling do not accept Googles Chromecast conditions. Chromecast is not "switched on".Too bad I can't turn disable Google Cast to test
I did so with my Essences, A6 and BS35. Since then no dropouts or any problems at all.
Quick update from Struer:
More than 2 weeks have passed now!
Any news?
@MM:
B&O sw dept issued a statement on Tuesday confirming that they have managed to identify the wifi issue and fix it. Tests so far shows that the issue is solved, but they will continue with more extensive test cycles to rule out as many side effects as possible (finally?). The release is said to be "in the next weeks" or as soon as possible - if there are no side effects.
Roger
Any word on whether Google Chromecast built-in will work in this new release?
So last sign from B&O was on January 30th. Still no firmware update. Since I am a Tidal user and not a Spotify user, this has effectively crippled my 2 A6's and my A9 ... Really hard pressed to sell them all and select Bluesound products going forward ...
I bought a bluesound node II
No wifi dropouts no app problems no nas problems
E 549,00 Euro's Great audio quality
