I purchased an A6 on Dec 22, hoping it would be Chromecast enabled. i immediately ran into many of the problems described in this thread. I guess I should have done some more research before shelling out the money... I contacted BeoCare and after a couple of days they provided the below response.
It is truly astounding that they're releasing SW without regression testing. In this day and age this should be standard procedure. It's also interesting to observe that the hardcore B&O customers (at least the ones participating in this forum) are tinkerers and experimentalists with a certain technical skill level. Back in the old days, B&O was the brand preferred by people without such inclinations. It just worked out of the box. These days, it seems you need an engineering degree to get anything labeled B&O to work (this includes yours truly, I should add!)
-bab
Thank you for contacting the B&O Play Support regarding your A6.
I am sorry you are not able to use Chromecast with your A6.
The
reason is that due to the WiFi problems we have experienced with our A6
and A9 products, we have decided to perform a software roll-back for
all customers, to the older but stable v.1.15.17640. That software was
rolled out on Wednesday December 13th 2017.
This
software fixed the important WiFi issue, but will unfortunately
introduce some other side effects. However, those don’t affect as many
customers as the WiFi issue affects. More specifically, those side
effects include:
- Chromecast built-in will not work with the roll-back software
- The improvements that were done on the Essence Remote connectivity will not be included in the roll-back software
- Might experience some issues with multiroom
A
new software update to both fix the WiFi problems and have the above
mentioned improvements are not expected to be launched until after New
Years.
So
please check whether the version mentioned is the current software
version for your A6, if so, and you wish to use Chromecast, and can live
with the WiFi issues, then please give me the serial number and the log
files, and we can manually push the latest software back out to your
speaker, so you get Chromecast support back together with the WiFi
issues.
Should you require further assistance, please do not hesitate to contact us again.
Kind regards,
B&O PLAY Support
Visit us at: link, link and link
https://d3r2mapsjipt0f.cloudfront.net/b2caca651ec6de79fea6fe5780318a82eb2ac38d?url=http%3A%2F%2Fbogo.custhelp.com%2Feuf%2Fassets%2Fimages%2Fbo_message_template.jpg" alt="Image"> |
The following question has been received:
Contact Information
- Email Address:
- First Name:
- Last Name:
Question Reference # 171223-000123
- Date Created: 23/12/2017 05.26 PM
- Date Last Updated: 23/12/2017 05.26 PM
- Status: Closed
- Smart tag: 171223-000123
Auto-Response By (Administrator) (23/12/2017 05.26 PM)
Phone home:
Phone Office:
Phone Mobile: Product: Sound Systems BeoPlay A6 Category: Installation/operation Language: English
Customer By CSS Web () (23/12/2017 05.26 PM)
I
have a brand new Beoplay A6. After unboxing it yesterday, the embedded
Chromecast client is not discoverable by Google devices or smartphone
apps around the house.
The critical events log displays the following error messages: * Cast starter failed, stopping * DSP error level: Service error * Google cast doesn't start after update, disable google cast
Please
advise when this error will be fixed, as it is unacceptable to market a
product as Google Cast enabled when it isn't. The advertised Google
Cast capability was a major reason why I purchased the product.
Looking forward to your response.
