I would assume so.In order to upgrade the Beolab 28 with this new release I assume I have to unpair the stereo first?
Thanks for the update, Carolpa. I guess I’ll have to think about a BLI. I haven’t even got to grips with my BLGWs yet… (sigh)Previous/next do work.No reaction. (same on BL28)addition: But one could make a BS9000 page in the Halo with 6 buttons, one for every CD station (just tested it. It works)
BeoLink Multiroom officially launched!
Improved for my part since the beta program, so now it does not matter any more if I start with my Balance or a non-Mozart speaker, and joining works like a charm back and forth too. Soooo happy! Waited for this for so long.
They have even bothered to update the Connectivity section on their product pages as well as support documentation, from what I can gather.
Terrific job, B&O!!!
Have you reset them after update? I did and everything works fine, listening to B&O radio right now.
Reset what?Have you reset them after update? I did and everything works fine, listening to B&O radio right now. New: Beovision Harmony, Beolab 50's, Beolab 28's, Beolab 18's, Beolab 17's, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay Portal, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube: https://www.youtube.com/c/Mikipedia Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4 Mikipedia on Intagram: https://www.instagram.com/mikipedi4/ Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
@mr_anders_son could you elaborate on crashing, the app is crashing? The crash happening here should be fixed. We are currently fixing some observed issues in an upcoming version 3.20.1. Should be out in a few days
Everything is empty.When I press ”show all” under B&O radio the app crash.@mr_anders_son could you elaborate on crashing, the app is crashing? The crash happening here should be fixed. We are currently fixing some observed issues in an upcoming version 3.20.1. Should be out in a few days Select correct tab in radio depending on what the product supports TuneIn favorites not starting when clicked Consistent error message when trying to play a radio service not supported Fixed occasional crashes in player when playing Deezer flow Fixed occasional crashes when browsing DLNA
