Beta for Mozart platform products available
Raeven wrote:
In order to upgrade the Beolab 28 with this new release I assume I have to unpair the stereo first?
I would assume so.
Carolpa wrote:
Previous/next do work.
No reaction. (same on BL28)
addition: But one could make a BS9000 page in the Halo with 6 buttons, one for every CD station (just tested it. It works)
Thanks for the update, Carolpa. I guess I’ll have to think about a BLI. I haven’t even got to grips with my BLGWs yet… (sigh)
Updated automatically for me without unpairing this time.
The update didnt do anything good for my BL 28😮
Can not do room compensation.
Can not unpair them so on and so on….
BeoLink Multiroom officially launched!
Improved for my part since the beta program, so now it does not matter any more if I start with my Balance or a non-Mozart speaker, and joining works like a charm back and forth too. Soooo happy! Waited for this for so long.
They have even bothered to update the Connectivity section on their product pages as well as support documentation, from what I can gather.
Terrific job, B&O!!!
Tunein and b&o radio does not work.
Keeps crashing👍
Have you reset them after update? I did and everything works fine, listening to B&O radio right now.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Reset what?
@mr_anders_son could you elaborate on crashing, the app is crashing? The crash happening here should be fixed. We are currently fixing some observed issues in an upcoming version 3.20.1. Should be out in a few days
  • Select correct tab in radio depending on what the product supports
  • TuneIn favorites not starting when clicked
  • Consistent error message when trying to play a radio service not supported
  • Fixed occasional crashes in player when playing Deezer flow
  • Fixed occasional crashes when browsing DLNA
Select correct tab in radio depending on what the product supports TuneIn favorites not starting when clicked Consistent error message when trying to play a radio service not supported Fixed occasional crashes in player when playing Deezer flow Fixed occasional crashes when browsing DLNA
Everything is empty.
When I press ”show all” under B&O radio the app crash.
