Best way to stream media to a BV7 1.gen
Hi there,
I also have the old type BV7.  I use Sony PS3 to connect the NAS to BV7 and it works fine.
You also need the optical to co-axial convertor for the sound or just accept the normal phono jack for the audio.
I have also connect the IR blaster to control the PS3 but you may need the firmware update to include PS3 in the PUC list.
Bouncer
Actually, one the 1 generation BV, there is no support for stereo sound through coaxial input AFAIK. You will need to run analog audio if you also want it to work with anything else than 5.1.  You might be able to opgrade your tv a bit (HW and SW) and have it work, but i dont remember if this was also an option for 1 gen BV 7.
/Ehlerz
