Best option for converting my 220V Beosystem 6500 to 110V?
I just bought a complete set of White Beosystem 6500 units i.e. Beomaster, beogram, beogram CD and beocord from Germany.
So far I purchased a 1000W Step up/Step down transformer and a German 5 plug surge protector that I plug to the transformer. So far in testing things seem to work but there is almost tiny barely audible hum from the transformer (Not unbearable). Also I have not tried the Beogram yet.
My question is if it is possible to have these rewired for US Voltage and plugs? Is it cost prohibitive?
What is the downside of using the transformer especially from a power consumption?
hello, did you manage to answer this qustion? thanks
i managed to get an answer, all beosystem components can be re-soldered for 110v! :)
hello, did you manage to answer this question? thanks
For most units that don't have a voltage selector, it's often simply a rewire to the transformer which most competent electricians should be able to do. Sometimes just jumpers to swap around.
Dave.
thanks very much dave, i spoke to b&o and the also confirmed that a resoldering job would be possible on all components!
Usually in the service manuals for these types of unit there is a schematic of which points at the transformer to use for various voltages. Silver and gold members of Beoworld have access to these manuals.
Dave.
