Best flat ceiling speakers for home cinema?
Thanks for all the advice! I think I will get a pair of Beovox 2 speakers as part of my home theatre system. But if the sonance speakers are as good as people here say I will put them in the rest of my apartment. Which of the models can you recommend (http://www.sonance.com/products/speakers#15,2), and what should I expect to pay for each speaker?
Beonic, remember that you will need a beolink passive for using the beovox speakers as they are passive and as I can understand your driver only allows you active speakers!
regards, Adrian
I have had success with the Moderno M6 series from Sonance.
