Best bluetooth receiver for use with B&O
With the H8 and Beolit 15, I am getting more into bluetooth than AirPlay, and I am looking to implement a bluetooth receiver to my system.
What are the different options for doing this? What are you using?
This question has been asked before , once by me and also this thread
/forum/general-discussion-and-questions/beolit-12#post-1983455
OK. But not really any good answers about it?
Not sure what happened with my previous post.
I wouldnt recommend the iwave bluetooth receiver - its rubbish. I never got it to work with my BS8.
Don't you need a transmitter for the H8? To put in the 3.5 headphone output of TV or Beomaster?
Here are some:http://www.amazon.com/s/ref=nb_sb_ss_i_0_17?url=search-alias%3Delectronics&field-keywords=bluetooth+aptx+transmitter&sprefix=bluetooth+aptx+tr%2Celectronics%2C417
This one does both. Transmit for the H8 or recieve for use with Beolit 12.
Avantree Saturn Wireless Bluetooth Audio Receiver and Bluetooth Transmitter 2 in 1 adapter, with aptX for Music and T
http://www.amazon.com/Avantree-Wireless-Bluetooth-Receiver-Transmitter/dp/B0085HOM4K/ref=sr_1_6?s=electronics&ie=UTF8&qid=1425068648&sr=1-6&keywords=bluetooth+aptx+transmitter
Regards Edwin
I can highly recommend the Sony bm10.  This support aptx and the sound is really great. I have it connected to beosound 2300 with beolab 4000 speakers
http://www.sonymobile.com/se/products/accessories/bluetooth-music-receiver-bm10/
I'm using the Nokia MD-310 in white:
Hi Leo,
Does the H8 com with a transmitter to connect to you Beosystem?
Al the other bluetooth deviced mentioned here are receivers. For sending music from your smartphone to the Beosystem. Is that what you are looking for?
The Avantree Saturn Wireless Bluetooth Audio Receiver and Bluetooth Transmitter does both.
I don't have one so I don't know what the quality is.
see also https://www.youtube.com/watch?v=l1VVQrT7da8
No it doesn't. In my opinion, one should use the H8 with a phone for wireless. If you want to listen from your home stereo; use the wire that the H8 is delivered with.
What I am looking for is a Bluetooth receiver with a decent DAC.
When I have been using Airport express, I was able to use the optical output into an external DAC of my choice.
Do you mean something like the Arcam rBlink?
