Best Blu-ray Player
TerryM wrote:
Beolab wrote:
Pioneer BD 80 and Denon´s new BD transport are the best.
Then Sony S350 and S550 are placed at second.
And the new Oppo BD with the Anchor Bay chip i think will be a hard one to beat!
How can one place the Sony S350/550 ahead of their flagship BDP-S5000ES?
It is a superb player,which is rated in some quarters as the equal of the much more expensive Denon 3800.
The PQ are the same in the S550 and S5000ES! It´s just the soundprocessing, dual lasers and built quality who it´s better in the ES series...
But the picture on BD are the same! Tacke a look if you come by a Sony Concept Center...
Regards
Regards
   this may be true with all of the S5000ES's additional PQ options switched off.
However,with it's SBM,and the Reality Enhancer,option engaged the BD PQ is taken to a far higher level than that of the S350/550 series.
I do own a S5000ES,but there are enough user reports on the relevent avsforum,and avforum,threads to indicate how it compares to other high end players.
Regards.
One question that has not been answered in any of these posts is do the PUC codes work equally well.
The Dennon is clearly a fantastic machine but has anyone actually used one with the B&O PUC codes? The same for the Panasonic and Sony machines.
Finally, is anyone having issues with decoding the new HD formats?
Just replaced our Sony BDP-S300 with the BDP-S550. So far I am very impressed and very happy with the 550.
i've had 3 ps3's in the last 18 months and have to say not terribly impressed with their reliability , my last one had to go back to sony with the game disc still in it , lost all my game saves , the lot
also the pic is very grainy , i've read that there are better players pq wise
pros : wifi sw update , games
cons : unreliable , grainy pq
i'd buy one for gaming and occasional movie watching , but for a superb tv like a bv7 i'd probably go for the top of the range denon , now that looks a real beauty !
why spend £8k on a tv then skimp on the source ??
My new setup includes a new BS3, BV4 50", Stewart Filmscreen 100" in ceiling, Beo 5, PS3 with Nyco USB dongle and a  B&O specified Samsung SP 800 A projector on a B&O PD2 lift.
I have found teh PS3 to be stunning (try watching Dark KNight, Kingdom of heaven, The Patriot etc). Incredible detail from 5 metres sitting distance. The PS3 performs reliably, is quick to start up and performance with standard DVD is excellent, although I suspect the incredible processing power of the BS3 has a lot to do with this. I would readily recommend the PS3. If a dedicated BD player is being sought I am reliably informed by my local B&O dealer that the Sony LX71 ($ AUD 1400+) is the mutts nuts. I am considering this. Of course the Beo 5 will have to be re-configured. I also believe the LX71 will be on the PUC list very soon.
Of course changing to a dedicated player means my two teenagers can stop monopoly of the Cinema screen for PS3 online gaming (Code of war thankfully relegated to the "small TV upstairs" . Yes !!!!
The panasonic BW 500 is also good but why would anyone currently pay for the BD recording facility ??
