Beoworld iPhone Application
Hey, everyone with an iPhone or iPad, the new version of the Beoworld App is now on the App store. It fixes the & bug and is now compatible with the iPad.
Check my App page to download it.
p.
Hi Phil!
Thanks, I have already downloaded it.
I hope it will not cut the postings any more. This posting will test it...
Regards
Räuber
It used to cut posts that contained the & sign, which is commonly used on this site...
Phil,
Why do you say it is NOT compatible with the iPad? It works briliantly!
I meant "now", not "not", I have updated the post!
IPad update is great! Thanks for the work on the app.
Cheers,
Frank
Thanks for this App that I use very regularly.
One thing that I miss is a search possibility. Would be great to be able to search through the forum.
Probably this can be added in one of the next releases.
Heribert
May I also add another issue?
If I reply for the first time in a thread from the App I don't get the Enable email notification which I find very useful.
Could that be also intergraded as well in a future update ?
WOW!!!!! That was very fast. I posted a new topic and it appears that it does work! BRAVO Philippe!!
Hello just some info I was monitoring the months prize draw on the app and I could only get up to two pages via the iPad
