First; Thanks for this thread.
It can serve as a good handrule guide for capactor upgrades to B&O speakers in general - and of course there's
a reason for me saying this;
People who know me will also know, that I have the greatest respect for owners wanting to do their
best for their vintage B&O.
They will also know that I have a deep respect for people who want to do things themselves.
DIY'ers are slowly becoming extinct, I feel.
So rest assured that this post was made with the best of intentions;
During many years, I've been recap'ing B&O speakers. Hardly a week between.
Most owners wanted best value for money, others asked for high-end capacitors - even in Beovox 2702s... - and I duly obliged.
This provided me with a good chance to try out and evaluate different solutions in countless Beovox speaker models
but let's take the Beovox Penta as an example. It's a fairly high spec speaker, one where any differences and/or
upgrades would be clearly audible;
Most Penta owners wanted a simple upgrade; Replace old electrolytic capacitors with fresh electrolytics.
A few wanted an upgrade to foil capacitors - some of which quite expensive.
Based on experience with at least 20 pairs of Pentas, I must admit coming to the conclusion that I cannot tell
the difference from electrolytics to foil caps and neither can I measure any difference, even using the
best instrumentation available to me.
Foil caps don't dry out - that's true. Foil caps should in theory last forever where the old electrolytics seems
to have a lifespan of apprx 20-25 years and modern electrolytics possibly just a little more.
But to me this doesn't make it up for the much higher cost of the foil caps and the problems of fitting
them neatly to the filter boards.
As can be seen in your photo, the foil caps are typically much larger and bulkier than the electrolytics and fitting them
to the filter boards can be a problem. It typically ends up with these, fairly heavy, components hanging by their leads,
vibrating and more or less rattling along with the music, eventually breaking their solder joints and/or leads.
I've seen it many times and it's a shame, really.
Some so-called "audiophiles" seem to care very little for things like this, feeling comfort in merely knowing that the
capacitors fitted have the right golden markings and did cost a fortune.
I've seen filter boards filled with screw-mount fittings that, paired with the unavoidable vibrations, provide a huge
potential for bad connections and contacts, let alone the rattling these plastic things on cables provided themselves.
It's my general experience that no passive B&O speakers will benefit from using foil caps, at least for the
coming 25 years. - And in 25 years from now new caps or filtering methods will have been developed, I'm sure.
99,9% of the lift in sound quality comes from replacing the old electrolytic caps with new of the same type.
That's merely a matter of bringing back the original specs.
Anything above this is pure theory. That's not just my opinion but also my experience (repairing and restoring
B&O audio units since 1976).
Returning to the Penta example; For DIY'ers I once provided - per countless requests - both a standard electrolytic kit
and a somewhat more expensive foil kit.
A few owners first had the standard kit fitted and later decided to "upgrade" to foil but none of them could tell
the difference, even in a direct neck-to-neck test and I must admit; Neither could I.
For the same reason, the foil kit is no longer provided. It simply doesn't give value and/or meaning.
From reading your thread, I understand that you've come to the same conclusion.
Anyway, I take it that you will find ways to securely fix those large components sitting outside the board ? You should!
And those blue "chinese" plastic lead-twists are merely temporary connections, right? - Because they are bad! Bad! BAD!
- particularly in vibrating environments like speakers and cars.
Last; For the odd surfer it's worth noting that the Beovox S60 came in different versions with slightly different filterboard
components.
If you are going to recap your Beovox S60s I suggest you check against your actual filterboards before ordering caps.
The list provided above is correct only for one version.
