BEOVOX S45 type 6302
Hello,
I'm new on Beowold.
I live in France in the Burgandy area.
I was given three pairs of Beovox speakers (two of which need repair). Along with a Beogram 4002 and a Beomaster 2400.
-The Beovox S60 type 6303 work perfectly. Very nice.
-The Beovox S45 type 6302 has one woofer with the voice coil stuck. I'd like to replace it with an original woofer. Any chance in finding one?? Would a woofer from a Beovox S45-2 type 6427 be ok?? (there's one for sale on ebay)
-The Beovox 2600 type 6224 has one woofer missing. It's a SEAS model. Any chance in finding that.?? Dillen might have one for sale so I might all right.
Thank you.
Freddy.
The S45 woofer could well be replaced by an S45-2 woofer - though I would replace in pairs - I'll see if I can fiind out if they changed the driver though I don't think they did. However the S45 Type 6427 is not a S45-2 but the later model which is completely different - foam roll and nothiong like as nice. Don't bother with that one.
Peter,
thank you for your quick answer.
Of course you are right the S45-2 are not type 6427 but type 6312. Sorry for misleading.
Your advice on changing the broken S45(type 6302) woofer in pairs with S45-2 was helpful. I only found one S45-2 woofer on eBay, so perhaps I should wait. Ideally I'd like to find a S45(type 6302) woofer for replacement as the other speaker works fine. Hope somthing comes up.
Freddy.
If the S45-2 is cheap, I would be very tempted to get it and use the woofer anyway.
I have some original Beovox 2600 woofers in stock (as you know) and I can also help you to an original S45 (6302/6312) woofer. All are used and tested. The same woofer is used in Beovox S45 types 6302 and 6312.
I would like to buy an original Beovox 2600 woofer (a SEAS model).
Please let me know the shipping price for France and your preference for payment (PayPal or other mean).
Yours faithfully
Freddy
Hi Freddy,
You have a PM (check your inbox).
Good evening,
i have a pair of s45-2 type 6312, one twitter is broken, i have to change it, do you know the reference and cost, may be bo don't continue to send it do you nknow wath's another speaker i can use?
Petronne
Hi and welcome to Beoworld ! 🤒
In the Beovox S45 (6312) two different tweeters are used through production.
I have some of both types in stock but I will need to know if yours are
AD 0162 T8
AD 0163 T8 ?
Do you have a woofer suitable forn an S45-2 type 6312?
Regards
Simon
