Beovox RL 140's
Three questions please....
1) What problems arise? Are any of the speakers with foam surround??
2) How do they sound in comparison to some of the powered speakers?  say connected to the Beocenter 9500
3) Most importantly, has anyone "re-furbed" a set of these.....what tips to make them look new????
Thanks..
1. Yes, they do suffer from foam rot.
2. They sound excellent when driven by the correct amplifier. The 9500 is not really powerfull enough to show them at their best. It will loose control, in particular of the bass when driven hard. Much better with 5500/6500/7000. Just my opinion, others will not agree.
3. Difficult to refurb as new because the cloth on the frets is unavailable. Some have re-covered with similar cloth but it is not to my personal taste. Unless B&O is perfect and looks original then I'm not really interested.
2. Agree with Graham. In common with the other big Beovox speakers, you need power to drive these multi driver units. One way would be to find some Beolab 200s. Have heard them drive a number of B&O speakers and they make a fantastic difference.
I've got mine hooked up to my BM6500 & they run fantastically.
Hmmm, anyone know where I can get a new band for one? It's snapped & sort of flapping in the breeze created by the cones moving an immense amount from gorgeously loud & clear sound.
This ebay seller does replacements but I've no idea how close they are to the originals.
(I'm not connected in any way to this seller BTW and have no vested interest).
Chris..
I've owned RL140 and used them with BeoSystem 7000. Excellent match in my opinion.
I love RL speaker design and looks.  White RL 140 with white BeoSystem 7000 would be something special to own.
Chris - Thanks. 🙂
Hi Graham...So on the "foam rot".....
1) which of the drivers suffer from this???
 2) Are the foam surrounds available?? if so where and how much...
Thanks,...Keith
The honest answer is I don't know!
I've only had contact with one pair that had rot and the guy sent them to Recone in Huddersfield UK to be fixed.
I assume it was the bass drivers.
I am thinking about getting this amp. How do you think they would sound with it?
http://www.radiomuseum.org/r/marantz_pm_710_dc.html
