Beovox P45 wall mount hardware
I stumbled on a set of P45s this weekend without the hardware. Seem to be in great shape but I am having  a hard time finding information about how these gems mount to the wall. Even a photo of the hardware and maybe some dimensions so I can Fabricate new ones. Better yet, if anyone has some laying around?
Welcome to Beoworld !
Brackets are ready at the back for both horizontal and vertical hanging.
Put two solid screws in the wall and hang the speakers like you would a painting.
There's no addtional hardware.
Can I assume this is also true of P30s?
  1. Thanks, great help! Love the speakers, now to find a place to mount them.
And don't fit them too high up on the wall.
Ideally (sonically), they should be at ear-height when you are sitting and listening, which normally
results in a surprisingly low mount.
Dillen wrote:
Yes.
Thanks, Martin.
My P30s will be hung on a wall in the garage. I will mainly listen while standing and working in the garage. As such I imagine my P30s will end up rather high on the wall in the end, but of course I will try multiple setups (as I always do).
Sorry for the intrusion but I have a pair of P45 which I want to start using again :) Do you know where I could buy the cables which on one side plug into the speaker and on the other into a System 5000 receiver?
You mean with DIN plugs in both ends? First of all - try asking your local B&O dealer.
- or ask Steve at Sounds Heavenly  (just look at the ad below)
Btw... Doesn't B&O have a factory in the Czech Republic..? Maybe  you could ask them... (or maybe not. They're probably too busy fixing the Avant assembly line) 👍
No -better ask in a B&O shop - or Steve.
You can buy the 2 pole DIN plugs for both sides of cable in any electronic shop, also in Conrad or even OBI, Baumax, Bauhaus...
Take care of the woofers before you do anything else!
