beovox m100 fix or partout?
By the way, the Celestion tweeters (not Philips Sir) can be repaired: new diaphragms are available here in France!
For a while there was an excess of m100 parts! How random! I am  finally putting them together. I went way overboard with rewiring the crossover, using small diameter shielded coax. I was curious if it will make a difference. Dunno yet.
I am wondering if anyone has a picture of the interior. I am not sure how the foam pieces fit.
Definitely see the need for stands and tilting of the speaker, bass stays really low to the ground.
It might be a tough call b/w my JBL L88 and Beovox M100. WIll see.
Here are lots of pictures from when I did refurbish mine.
That is exactly what I needed! Thank you! I don't know why they did not come up on google...
You, btw, did a marvelous job with yours! I noticed you rebuild the crossoveres too! Was there a noticeable change in sound?
Do you, or did you also observed this slight flatness of low tones/bass?
Thanks again!
Hello,
Resurrecting a 7 year old thread, sorry.
I'm looking for a replacement dome & voice coil or wholesale replacement of the M100 mid-tweeter.  Can any of you direct me to a source?
