Hi ;-)
To make a long story short(er), I went looking for a pair of Beovox 901 to match an old Beomaster 901 heirloom.
I ended up with a great little pair of 901's, but during my search I found a completely brused and abused pair of Beovox 3000 (6210, I think) and - against my better judgement - I fell head over heals in love with them!
They will need a LOT of tlc, but all drivers seem to be working, as best I can tell - except for the one woofer. It had been replaced with an unoriginal woofer, but I managed to get a hold of the original one. And defective it was, no doubt about it.
When pushing the cone down lightly, it gets stuck. Also I can't get an Ohm reading, why I suspect the coil to be broken in one form or another.
There you have it - this is my starting point - and I have a very clear vision in my mind of a very, very steep hill ;-)
I have absolutely NO idea if the woofer can be repared or if a replacement even exists?
I would very much appreciate any help with the woofer issue, as it is kind of a deal breaker to the entire project - no woofer, no point in taking it any further.
Regards,
Jesper...
