Success indeed - I PM'd you back :)
Beovox 5000 Panel Speakers
I'm after a set in Blue if anyone has a spare set................
I once had a setup with beovox 5000 panels (wall mounted) driven by a Rega internal amp and the signal came from my ouverture. It sounded very nice and was also able to play qiute loud. The tweeter dome on the Beovox 5000 panels are in the mittle of the speaker, so you should try to mount them so that the tweeter is in the same height as your years when sitting inthe sofa (or whatever position you prefer to listen to music in...).
good luck
Christian
I actually still have the speakers, I hope one day to match them with my Beocenter 9000 (which is also sitting in the closet)
Hi all,
I just bought my first Bang & Olufsen, a Beocenter 9500 and I am wondering is it capable of handling a pair of Beovox 5000s ?
The 9500 is well able to handle a pair of Beovox 5000's.
Hi stt
The BeoCenter 9500 can certainly handle a pair of Beovox 5000. I have a BC 9500 which now is connected to a pair of Beolab 5000 (so I don't use the amp in the BC).
But i have earlier had several different Beovox'es connected to it - from CX 100's, over MC 120.2's, to Pentas. It's not the most powerful amplifier -but it can play pretty loud anyway. No problems -and a wonderful sound.
By the way -the 5000's is not that rare here in Denmark 🙂 Right now there's a pair of 'voxes for sale on a market called 'dba.dk' for only 950,-DKKr (around 100£). I would have bought them, if it wasn't for the fact that I already have the Beolabs, as mentioned above (among with many other Beovoxes) -so I don't have the room for it 🙁
I don't know if the seller is willing to send them out of the country.
I don't think they are for sale anymore, Steffen, cause I can't find them... 🤔
- Dennis
Sorry - my mistake. 😳 (think I'm getting old)
It is actually another site! Try this:
