Beovison 5 Mark 1 upgrading to HDMI and 2020
Hi All
I have a beautiful Beovisoin 5 and really want to spend some money on getting it in to the year 2020.
So I want to connect this to the best option for HDMI, HD and any tech product such as Apple, Amazon Firestick etc.
So can you suggest the best solutions available and are there any online/YouTube videos/guides on how to install?
Alvin
I used one of these with my Beovision 5 and my FireTV
Along with this
It worked well. I also connected a FLIRC USB and could control the FireTV using a PUC on my Beovision 5 and my Beo 4 remote. I installed KODI on the FireTV and it worked brilliantly. (it worked with my Firestick V1 originally, but I updated to FireTV).
Stoobie
Exeter,
Devon,
UK
Thanks Stoobie. Does the eSYNic need power, doesn't look like it?
Excellent. Do you know if they do a converter with more than one HDMI?
It definitely needs USB power. I have a wall socket with 2 USB outlets and use that.
Here us the convertor on Amazon
https://www.amazon.co.uk/Converter-Composite-Adapter-Digital-Signal-white/dp/B00A6STNHM
One of those and something like this may work
https://www.amazon.co.uk/UGREEN-Support-Wireless-Control-Blu-ray-Black/dp/B00MWRZFP4
You can feed 3 HDMI in to one HDMI out, the into the convertor. A bit unwieldy but should work and that particular one has a remote for switching from one HDMI to another.
Stoobie
Exeter,
Devon,
UK
Hi again,
They do this now. It was not available when I bought my adapter.
https://www.amazon.co.uk/Duttek-Converter-Output-Adapter-Composite/dp/B086YM54K7
But that and the 3 into 1 HDMI switch should work well for you and fewer connections etc.
Stoobie
Exeter,
Devon,
UK
Yes I saw this I assume this would need a Scart to Scart? Is so I wonder why they didn't make it so that it goes straight into the back of the TV rather than a double ended scart lead?
Probably to do with how much it will stick out at the back. Or the added cost of making a swivel connection.
It will definitely prolong thr usefulness of your BV5. Fabulous TVs with amazing sound. We loved ours.
Stoobie
Exeter,
Devon,
UK
Hi Alvin,
I see you are here in the UK. I no longer use the eSYNic I have. I'd be happy to pop it in the post to you. You'll just need to get a few cables.
Stoobie
Exeter,
Devon,
UK
Do you not use yours anymore then?
