Hi
I am trying to connect my Mac Mini to my Beovision7-40.
I have connected it to the VGA connection on the Beovision7-40, but do anyone know who I connect the sound on the Beovision7-40?
Best regards
Jacob
Hi
Best regards
Jacob
That is a good question, and I did not find it.
But also if I try 1920x1280, the screen remains dark. What resolution did you adjust?
I only think below resolutions are supportet.
VGA, 60 Hz, 64 0 × 48 0, 848 × 48 0, 1024 × 576,
800 × 600, 1024 × 768 , 1366 × 768 og
1280 × 720.
But it is very strange, regarding the sound I do not belive that they have made a solution for computer vga connection but without sound supported.
Best regards
Jacob
I solved the problem by buying the Apple TV. I know this doesn't answer your question as such because you still want to connect the MAC mini but I can tell you that the ATV is a great piece of kit and will do everything you want. If not, hacks are available for it.
Simon.
I have the sound from my PC connected to L-in and R-in on the AV 5 output in my BV-40 ,the sound works fine might try spdif next to see if gets any better .
Rhone
Hi Rhone,
Thanks, that worked.
The only thing is that I used AV5 for my satelite recieve which only have the yellow, white and red cabel. But I will use a scart converter for that instead.
Best regards
Jacob
