BeoVision with Homecinema wanted in 2022
MM makes some very good points. I used to use my projector in a B&O CINEMA mode all the time before larger tv screens become mainstream. Now, I have a 75 inch tv screen with a BeoSystem 4 with a projector as the second video output. You need a special Atlona splitter to make this work. I've found that now with a 75" tv that I never use my projector with a 100" screen. The tv is brighter and has a better picture. Also, there is no need to worry about keeping out light. I just don't miss the projector.
However, if your concern is keeping the tv presence small in the room, I can understand your desire to have a projector. There was a time when I had no tv in the room and just had a motorized screen that retracted to have a large piece of art on the wall. I liked the elegance of not having a tv being so prominent in the room.
I jaust had a 2h talk with my wife and what we plan with our Homecinema. We now decided to have a look for a BV7-55 and change speakers to built in in-ceiling ones.
The rest will stay the same. We then will have a look in a few years if we can replace the projector with a bigger screen.
Thsnks for all of your help.
Millemissen wrote:
If you still want to keep the projector solution, get the BSys3 going.
No big investment needed there - other than some cables the right ir-eye, an ir-blaster for the projector (if not already there).
You’ll need to have the System updatet with the newest Apple PUC etc by a B&O dealer.
Could suit you well the next couple of years….untill you might go for a big B&O tv solution 😁
For the ‘small tv solution’ get a recent LG tv, a BS Stage and the Beoremote one.
Keep them seperate.
Trying to establish a ‘B&O Cinema Mode solution’ nowadays will not be worth the efford, if you look for simplicity…..unless you decide for a BV7-55 as a direct replacement.
N.B.
No Homecinema without a sub!
Please don’t let your wife let you ditch the BL2 😁
The BL2 will stay to be honest she asked if we could add a second one ;-)
Millemissen wrote:
N.B.
