There are a couple of threads on using LGs / other OLEDS with a Beosystem - some of them go into detail, and there are certainly a few that have made this kind of setup work.
Basically involves some piece of kit to split the audio and video outputs from your sources - send the audio to the Beosystem and video to your displays.
Getting the BR1 to control everything I think can also be done - but that requires a bit of a hacky solution.
The simpler solution is to get an AV processor, one with outputs for a TV and projector. That means no BR1 for control - you need a B&O brain somewhere to facilitate that, and the LG app on current LG OLEDs need a modern B&O brain (Stage, Eclipse, Harmony) to allow a BR1 to control the TV. The LG TVs B&O app will not recognise a BS3 / 4.
The AV processor route is worth thinking about - yes no BR1 control, but a new TV will have most apps you need. Depends on how many sources you will want to maintain really. Many AV processor remotes are a bit nicer than the LG TV remote, and will control the LG and its apps. May be enough for you, and avoids sending you down the road of a complicated (to install) setup.
Tim84 wrote:
So as far as I understand if we want to keep our TV and projector setup we have to use a BeoSystem 3 or BeoSystem 4, right?
The reason why we want to keep that combination is that we want to have a small TV for daily use and a big screen for cinematic evenings. We have a projector lift in the ceiling and automated screen with 120" and that will always be way beyond we can go with a normal TV.
A few questions that come to my mind.
- we have an old BeoSystem 3 (9600) fully equiped somewhere in the garage. Would this be good to start?
- what is the great advantage of a BS4 compared to a BS3? Only NL or does it have 7.1 and more supported audio formats?
- can we control for example a LG C1 through the BeoSystem?
- Where do we connect the sources to? BeoSystem or the new TV?
- can we use the built in AppleTV and Apps in modern TVs? I suppose we then can't use the projector right?
- We want to use BoLabs for front left and right and in-ceiling speakers for center and rear left and right, any recommendations?
- what do we need for in-ceiling? speakers and a Amp?
- which speakers would you recommend for front if the space is limited? BL18, BL20, BL9?
Thanks for your help. I know it is a lot of questions but it seems our setup and needs are not "normal".
